Which is the Best Power Bank Charger for Travel?
Today, no matter where you are in the world, you have the ability to check your emails, play games online, find your way to a specific location, watch TV shows and movies, and more, all on electronic devices small enough to fit in your pocket, Â This is why smartphones, iPhones, and tablets are perfect for travelers, You can also do all the same activities on a laptop when you are traveling.With an increase in travel electronics requiring charging, it has become essential for people to have a portable battery charger to help fill the power lag when traveling.
A power bank charger is one of the important travel devices for international travel today. This includes travelers who do not stay in one place long enough to charge a laptop, iPhone or tablet such as people who love backpacking through places like Europe or Asia. Portable power banks are also ideal if you are in a location where power availability is an issue, So, what is the best power bank charger for travel?
Staying within easy access to a power outlet can put a damper on the fun of traveling, but fortunately power banks keep devices charged while still giving travelers the ability to explore beyond electrical outlets such as in hotels. When searching for the best portable power bank for your travel needs, it is important to be aware that not all portable chargers are created equal in quality, capacity, build, or price. Portable power banks come in all shapes and sizes, but they do essentially perform the same function - allow you to charge a smartphone, iPhone, tablet, laptop or other device.
Which Power Bank Features Are Important for Traveling?
With so many different types of power bank chargers on the market, it’s not always easy to know which features matter when buying a portable power bank. First, capacity is important. You should know what devices you will be charging and approximately how many times per day or two. For instance, a tablet requires more power than a smartphone. Charging one device or multiple devices several times requires a higher-capacity battery. For example, the iPhone 8 has a 1821mAh battery, while Android smartphones are typically between 2000 and 3000mAh. laptops have an even higher mAh battery. Also, it is important to be aware that to fast-charge the latest devices, you may need a battery that can output up to 3.0 amps.
There are few practical features to consider when shopping for a power bank. This includes size, weight, ports, and plugs. A Â high-capacity power bank to charge multiple devices at once will require enough USB ports. There can also be a maximum power output across all USB ports for some power bank chargers, which means that charging will slow down when multiple devices are connected. If you want to put the power charger into a pocket, it is important to be aware that size and weight of a charger increase with capacity, Â However there are high capacity power banks that easily fit in a small carry-on bag or backpack.
High-Capacity and Great for Travel
The high capacity Zendure power bank A6PD 20,100mAh Portable Charger with USB-C Input/Output is an example of a quality high capacity power bank. This power bank provides high-speed charging for USB Type-C PD enabled devices such as the 13" MacBook Pro, Nintendo Switch, most Android phones, tablets, Laptops and more. It also delivers fast charge for iPhone X, iPhone 8, or iPhone 8 plus up to 50% in just 30 minutes thanks to USB Power Delivery.
As a high capacity power bank, A6PD 20,100mAh Portable Charger fully charges your MacBook 1.5 times, iPhone X 5.5 times, Nintendo Switch 2.5 times, and Galaxy S8 4 times. In addition, this power bank also has Pass-Through Charging so you can charge Zendure while charging your devices at full speed with a single wall charger, a feature rarely seen in other power banks.The A6PD Portable Charger not only provides USB Type-C Port as input and output, but also regular 2.4A(Max) Micro-USB input and 2.4A(Max) USB-A output.
Charge On-the-Go While Traveling
It is never a pleasant experience to find yourself stuck without charge and power supply while traveling, especially when you are travelling to a place or country that you  have never visited before. However, due to the modern power bank chargers and other portable charger solutions, you will no longer have to experience such a distressing situation. Because portable electronic devices have become commonplace, it is a good idea to carry these portable power banks at all times when traveling in other countries, particularly in countries that are prone to regular power outages such as India, Nepal, and also for any travel on airplanes, buses and trains.
Power bank chargers are used for charging many devices we carry with us on the road or in the air, including charging iPhones, Smartphones, Kindles, Blackberry,gaming devices such as Nintendo DS, laptops, tablets, and iPads, If your travel plans involve long journeys, travel to remote areas, and other countries, you should invest in a portable power bank charger. Whether you want a large power bank to charge your laptop or a pocket-size charger to top off your devices, a portable power bank is a very  useful addition to your daily travel carry kit.
