Top USB-C Power Bank for DJI Osmo Pocket
DJI Osmo Pocket Selfie
DJI released its new Osmo Pocket camera, a 3-axis stabilized handheld camera with intelligent features, on November 28th, 2018. DJI Osmo Pocket sits at about 4 inches tall, which is compact and small enough for anyone to carry and put into their pockets. It features the most impressive HD shooting design with a 1/2.3-inch sensor that records 12-megapixel photos and 4K video up to 60fps at 100Mbps, making it ideal for shutterbugs. Its intelligent design allows you to capture superior video and photos by pushing the button above the camera. The superior design makes it easy for shutterbugs, travelers, adventurers and couples to carry around to capture creative videos and images in their life.
Battery life of DJI Osmo Pocket
DJI Osmo Pocket Charger
DJI claimed that its new Osmo Pocket features 140 minutes of battery life at 1080p 30ftps and around 2 hours at 4K with a slightly lower frame rate of 30ftps. What does it mean? It means that if you want to shoot clear images and videos of people and scenery, it just supports about 2 hours shooting continuously. Is it enough for shooting when you are out? It really depends on how you use it.
Battery Capacity and Energy
Using DJI Osmo Pocket
DJI Osmo Pocket battery capacity is 875mAh and the battery energy is 6.738Wh. As what the early adopters said, there was no power adapter or charging index in the package, except a power cable. If you use the traditional iPhone charging adapter, the charging time will take about 2 hours. It means you need 2 hours to fully charge your camera just for about 2 hours continuous shooting. It lets most users down. Fortunately, there are many high capability power bank for your backups.
Charging and Connectivity
DJI Osmo Pocket USB-C Port
There’s a normal USB-C to USB-A power cable included in the DJI Osmo Pocket package. The charging and connectivity can be realized by a USB Type-C connection at the bottom of this tiny Pocket camera.
Top USB-C Power Bank for Osmo Pocket
Zendure A8PD Portable Charger for DJI Osmo
The Zendure A8PD 26800mAh power bank is a great option if you're looking for a way to extend the battery life of your DJI Osmo Pocket.
The super-fast charger features with USB-C input and output. Thanks to its 26,800mAh sky-high capacity and 30W power delivery, it can quick charge your tiny Pocket camera within a short time. And it can recharge the Osmo Pocket by several times.
It takes 4 hours to full charge this Zendure high capacity power bank. You just need to charge it before you sleep without worrying about overcharging issue for its safety protection design makes it able to protect against overheating and overcharging. Everything is ready for your tomorrow shooting. Moreover, you can easily read exactly how much juice is left by the LED Digital readout.
Zendure A8PD Portable Charger for DJI Osmo Pocket
Can you charge the Pocket camera while shooting? The answer is absolutely yes!  You can charge the DJI Osmo Pocket via USB-C connector of Zendure A8PD power bank while you are using camera. This user friendly design makes it very convenient for your daily shooting.
Clearly, you've got options. We hope that this guide has helped you make the best choice for your needs.
Browse Portable Chargers
