The Best Way to Charge a Phone in a Car in 2018
Having a charger in the car has become a necessity as our smartphone batteries get drained when using navigation apps and playing music. You may have a USB port if you have a newer car model, or stick to a charger in the cigarette lighter. But time and time again, it may seem like your phone is hardly charging at all.
If you are fed up with slow charging speeds in the car, it’s time for an upgrade.
Why Do Our Cars Charge Devices at All?
How did it become standard to be able to charge a device in your car? The sockets used in cars are called cigarette lighter receptacle, or cigarette lighter sockets. These were originally designed to power an electrically heated cigarette lighter at a time when many people smoked cigarettes.
Later this socket became a way to supply direct current (DC) power to portable accessories used in the car like lights, fans, or air compressors for inflating tires. Today, many cars still come with a cigarette lighter receptacle and many new models have a standard USB port.
The Car Charger, Upgraded
Our newest release, Zendure QC 3.0 Car Charger is the charging upgrade you’ve been waiting for. With Qualcomm Quick Charge 3.0 technology, you will be able to charge your device at the fastest speeds possible.
The QC 3.0 Car Charger has a QC port which outputs up to 18W and one standard USB port delivering up to 12W. Your device will be charged and ready to go before you know it. And with two port available, you friends will thank you too.
Here at Zendure, we want to make charging your device while driving as easy and safe as possible. The QC 3.0 Car Charger is unobtrusive and won't get in the way of other controls while you are driving. Your device will automatically start charging when plugged in and an LED status light will let you know when your phone is all charged up.
Need Even More Power in the Car?
If two port is simply not enough for all of your devices, or you need even more power for certain devices, a car charger isn’t going to cut it. That’s where portable chargers come in.
Our Zendure A8 QC Power Bank can charge up to four devices at once and has a ridiculously high charge capacity of 26,800 mAh. This monster juice box has certified Qualcomm Quick Charge 3.0 Technology, so you can charge your devices at the fastest speed possible.
When you are in need of something that charges quick, has plenty of juice, and extra ports, the A8 Power Bank is your go-to charging accessory. And with this portable charger, you will always know exactly how much charge you have left with an LED indicator.
The best part about this power bank is it is truly portable, so you can leave it in your car or bring it wherever you go!
Charge in the Car with Ease
At Zendure, we want to give you choices that perfectly suit your needs. If you are tired of your prehistoric car charger with slow charging speed, it is time for an upgrade. With lightning-fast charging speeds, the QC 30W Car Charger or A8 26,800 mAh Power Bank will make you wonder how you ever survived without them.
Written by Michael Smolski.
