SuperMini Portable Charger and Leather Case Now Available on Zendure.com
Zendure has made their SuperMini 10,000mAh Portable Charger available on their website, along with a leather carrying case designed specifically for SuperMini.
SuperMini is a surprisingly small 10,000mAh portable charger that delivers up to 18W of power. Featuring a USB-C input/output and USB-A output port, SuperMini is capable of pass-through charging, allowing the user to charge SuperMini and another device at the same time.
SuperMini's small size is thanks to its super-high-density lithium-ion battery cells. Each cell has a capacity of 5,000mAh, so SuperMini can store up to 5,000mAh using just two cells instead of the three cells found in conventional chargers with the same capacity. The result is a portable charger that is small enough to hide under a credit card, that can still recharge a typical phone two or three times.
The power bank also features "X-Charge Mode" for compatibility with low-power devices like fitness bands, smartwatches, and wireless earbuds.
The leather case delivers protection and convenience when using SuperMini, keeping all sides secured while still providing access to the ports, lights, and button. The integrated clip can be used to attach SuperMini to a bag, backpack, or belt loop.
SuperMini debuted on Indiegogo last August and has brought in over $300K in crowdfunding from 5,500 customers. SuperMini is available in black, silver, and "Blue Horizon", a gradient of sky hues.
