Best Travel Plug Adapter in 2018
It has become an increasingly necessary to keep your gadgets (mobiles phones, tablets, kindles, cameras, game consoles, laptop, hair dryer, hair straightener, electric razor etc.) charged up while traveling. And since different devices may need different plugs, it would be both annoying and tiresome to bring all kinds of chargers and wires.
First let’s talk about the charging problems we usually encounter when traveling:
Easily Broken Fuse
Normally each adapter obtains fuse with small size, so it would be rather troubling to bring it, much less to change it when it gets broken. Furthermore, fuses in general travel adapters are only for one-time use. In case someone is not familiar with it, following is its specific location in adapter.
Multiple Devices and Chargers Add Extra Burden to Trip
Carrying a growing number of chargers & wires is a pain. As annoying as it is to forget a charger, it’s probably equally annoying when you need a different type of adapter for each new country. To top it off, different countries adopt different voltages & socket types (Usually ~100 – 240V~). Plus the shape of outlets varies from country to country. For example:
In many cases, travelers will need an adapter to fit the plug into a different shaped outlet. A good travel adapter can typically work in most if not all countries, but a great one enables quick charging, catering to multiple devices, protects your devices and reduces the number of charger plugs you need to carry. Travel Adapter, Zendure Passport carries all these merits. Let’s see more details about it.
Amazing Auto-Resetting Fuse
Zendure Passport is the world's first global travel adapter with an auto-resetting fuse. The auto-resetting fuse (patent pending) allows Passport to recover from overloads without service or replacement. Thus you will refrain from worrying about frying your electronics.
User-Friendly Design
Zendure Passport has easy “press and slide” button. With this Passport, you only need to use one hand to push the country buttons, and slide to extend the power connector directly.
Zendure Passport has four powerful USB ports. Therefore it will be compatible with most of the daily-use devices. Zendure Passport is the smallest international travel adapter with four powerful USB ports (5A/25W max), the highest in the industry.
Adapting to all shapes of outlets
As a worldwide universal charger, Passport travel adapter covers more than 150 countries with USA/UK/EUROPE/AUS/CA/JP plugs, which work in USA, UK, Europe, Canada, Japan, Mexico, Brazil, Central America, South America, Asia, the Middle East, etc..., so you don’t need to worry about buying different adapters every time you are traveling a different country.
Beautifully Designed Outer Package
From its appearance, a great design, which made it the winner of 2017 Good Design Award™. Besides, it’s superior in its packaging as well. Passport Travel Adapter’s simple but high-end design makes it look more attractive than other similar products.
Inside the box there are warranty and customer card, which can protect against defects for 18 Months from date of purchase from an authorized retailer, a cloth pouch to keep the adapter away from dust, and a user guide as well as stickers to beautify your adapter or luggage, and of course, the adapter.
The most considerate design in Zendure Passport is the baby-proof outlet, especially for those families who have a mischievous toddler. Besides, its 6A Max AC output can have you enjoy top charging speed with a "Zen" peace of mind. With a beautiful designed and included built-in power adapters for nearly every region of the world, you will definately enjoy a burden-free journey abroad.
Featured in fast charging, auto-resetting fuse and user-friendly design, it’s fair to say that Zendure Passport qualifies the title of Best Travel Adapter in 2018.
