Best Accessories for FIFA World Cup
As it began on June 14, the FIFA World Cup has become a hot topic that causes excitement, but also great concern. You can see people watching World Cup anywhere, on the sofa, in restaurants, even on the street. The World Cup will lasts for nearly a month, and for 9-5 workers, it is almost impossible to drop from work and pay attention to the World Cup until its closing comes. For the greatest enjoyment of World Cup, you need to prepare some basic accessories.
First: Power Banks
Power banks provide convenience by juicing up your smartphone while an outlet is beyond your reach. Also, they ease the worry of a dead smartphone battery. Based on the basic standards of size and battery capacity, here are some suggestions.
Portable Power Banks
Zendure A1 Portable Charger
Zendure A1 is the best portable experience with its weight at 68g and size at 3.8" x 1" x 0.9". It shaped like a beautiful and durable strip which can be easily put into the pocket. The color currently comes in magenta, a pretty, stylish and attracting color. The battery capacity is 3350mAh, a satisfying capacity when we connect it to its portable size.
Zendure A2 Portable Charger
Zendure A2 weighs 140g, twice the weight of an A1. One reason is because of the larger volume it holds---6700mAh. However, it is also portable enough to be put into a pocket with its size at 3.7" x 2" x 1". Portable as it is, the effectiveness of Zendure A2 will never let you down. Zendure A2 is able to charge your device with maximum speed up to 2.1A. Also, it is compatible with almost all Apple and Android smartphones, tablets and other USB-charged devices, to bring you the utmost convenience.
Fast Power Banks
Zendure A3TC Portable Charger
Zendure A3TC is outstanding for its effectiveness as it is designed with a USB-C input/output and a USB-A output for versatility. The USB-C port is able to charge your device at a high speed with 5V 3A output, which successfully beats many normal power banks whose outputs are generally 2A. Another competitive part of Zendure A3 comes at its impressive crush resistance. According to Zendure official website, it can survive being run over by a sedan, which simply means that you are free to put it anywhere in your bag or suitcase without additional protection while traveling.
Zendure A8 Power Bank
Zendure A8 is impressive for its large capacity (26800mAh) and quick charge technology. With a 26,800 mAh capacity, this monster can easily extend your phone usage 7-9 times, and takes only 10-12 hours to charge using a QC3.0 charger. There are four output ports on the frame, one of them is a quick charge port and the other three are standard ports. With its charge-through function, it allows you to charge your alternative devices while still charging your power bank. Zendure A series products do a great job in battery storage. We promise that A-series battery can maintain up to 95% of its charge after six months without use.
Second: Versatile Wall Chargers
For World Cup fans, to find someone to share the most exciting moment with is even more enjoyable than being alone. You can simply sit together in front of the TV set and cheer loudly for every goal. Yet when TV is not available around you, it is necessary to get prepared with a versatile adapter, because every smartphone needs charging while its battery consumes at high speed. Here is a suggestion.
Zendure Passport Global Travel Adapter
Passport is beautifully designed with built-in power adapters for nearly every region of the world. There are four USB ports (5A/25W max) on the frame, which allows four devices get charged at the same time. Additionally, the several types of plugs built in that allows for usage internationally. Passport travel adapter covers more than 150 countries with UK, USA, Australia, Canada, Europe, and Japanese plugs and can be used in USA, UK, Europe, Australia, Canada, Japan, Mexico, Brazil, and Asia and so on.
To sum up, while enjoying the excitement of FIFA World Cup, never forget to back up your device, as you will never know what you are missing of your battery dies.
