3 Tips to Quickly Charge DJI Osmo Pocket
DJI's Osmo Pocket is a dedicated video/photo powerhouse. One of the best features of Osmo Pocket is its common port, which can be used to connect various accessories. Some of the accessories DJI has announced so far include:
  • Waterproof case
  • Smartphone adapter for iPhone and USB-C Android phones
  • 5mm jack for a microphone
  • Charging case
  • Selfie stick
  • Official charging cable (power adapter not included)
The camera comes with an 875mAh battery that lasts up to 140 minutes. If you use an iPhone 5V/1A conventional charging adapter, it will need two hours to fully recharge.
DJI Osmo Pocket Yellow Background
Are there any tips to charge DJI Osmo Pocket quickly?
140 minutes may not be enough on-time if you have a lot of footage to capture. Therefore, a power bank is a must-have. A power bank with large capacity, like SuperTank from Zendure, has the high-speed performance and durability necessary to be a true companion for DJI Osmo Pocket.
Zendure SuperTank Portable Charger
  • A total of five outputs.
  • 26,800mAh super capacity to charge Osmo Pocket for many times.
  • Power Delivery (PD) charging protocol to reduce the charging time for Osmo Pocket.
Browse Portable Chargers
While you can use any charging adapter to charge DJI Osmo Pocket, SuperPort from Zendure is well-suited for charging DJI Osmo Pocket. It has several outputs and high-speed charging performance to make quick work of recharging your Osmo Pocket.
For top charging performance, temperature must be taken into consideration. Charging at a 5 ℃ to 60 ℃ environment temperature is appropriate. However, once the temperature of Osmo Pocket itself reaches 45 ℃ to 60 ℃, the charging speed will be limited to protect the battery, and it may not be fully charged.
If you're looking for something compact but can deliver better performance than a typical smartphone camera, DJI Osmo Pocket sounds like a solid portable camera and a good fit for you!
Also read: TOP USB-C POWER BANK FOR DJI OSMO POCKET
